Previous in Forum: Piping Design Study - Book & Course Recommendations   Next in Forum: What is the Braking Power Required
Update on Eyewash Water Chattering Problem
05/19/2010 7:03 AM
Thank you to those whom offered help with my problem. The problem was the regulating orfice in the spray head. It was a plastic washer with a hole to limit the flow, on the under side of it was a cone shaped rubber seal that kept collapsing. Go figure. Thanks again.
I refuse to succumb to the will of an inanimate object!
Good Answers: 299
Re: Update on eyewash water chattering problem
05/19/2010 7:25 AM
Hopefully, this was discovered before you chopped a hole in the wall .
05/20/2010 5:06 PM
Yes, yes it was. The only problem was finding a replacement part. Had to buy a new unit!
Re: Update on Eyewash Water Chattering Problem
05/19/2010 7:52 PM
Thanks for the feedback.
05/20/2010 1:28 AM
You are welcome, I am the Guest that suggested the "washer in faucet" in your initial post.
Good Answers: 299
05/20/2010 8:57 AM
This washer is not the volume regulating valve, it is in the diverter.
05/20/2010 5:10 PM
Thanks for the suggestion. What thru me off was a threaded washer with 4 holes in it, and below that was the culprit washer with the rubber seal. Thanks again.
Register to Reply 6 comments
Anonymous Poster (1); Doorman (2); lyn (1); Toomany (2)
