Previous in Forum: Update on Eyewash Water Chattering Problem   Next in Forum: Quick Release Mechanism Must Withstand 50,000 lbs When Fastened
What is the Braking Power Required
05/19/2010 8:52 AM
Hi
I want to calculate braking required to stop a 150mm diameter shaft rotating 3600 rpm, with a disc attached at the end.
You can give me the formula if i did not supply enough information
Thanks,
Deepcut1
deepcut1
Re: What is the Braking Power Required
05/19/2010 9:36 AM
Energy (Kinetic) / dissipation in seconds = Power
However actual requirement will be (if mechanical drum type) depending upon the friction coefficient between the drum and the shoes friction coefficient etc...
You may like to have a look here
05/19/2010 11:58 AM
Hi
Thanks , anywhere my question is a bit vogue, lets take it way can you a formula for braking power of disc brake.
Thanks
Deepcut1
deepcut1
Good Answers: 60
05/19/2010 10:14 AM
05/19/2010 12:41 PM
For starters you need to provide the desired ammount of time it will take to stop the mechanism. lets say for now you want it to stop in 1 second:
the energy of the disk is calculated as follows: T=0.5*Io*omega^2
where: Io=0.5*mass of disk*radius of disk^2
omega=speed of rotation in RADIANS per second (google on how to convert)
now, calculate the 'rorational energy' of the disk AND the rod itself(add them together), divide that by the time you want it to stop, and thats the power that you need.
in reaily, the power that you need will be much lower because friction will slow the system without any applied breaking power... but at least this should give you a rough idea of the maximum power you might need...
Good Answers: 137
05/20/2010 5:30 AM
Strictly speaking, you don't "need" energy to stop it. In principle, you could recover energy.
Length and density of the rod, and disc details are needed to calculate total moment of inertia. With time available to stop it (not given by OP) can then calculate the torque the brake must apply.
Energy useful as a check on whether the brake is likely to overheat.
Cheers.............Codey
05/19/2010 5:03 PM
Braking power of anything depends on how fast you want to stop it.
Register to Reply 6 comments
Anonymous Poster (2); Codemaster (1); deepcut1 (1); enginenear (1); peterg7lyq (1)
