Previous in Forum: 220kV Circuit Breaker S.C MVA.   Next in Forum: Choosing of Excitation Systems:
Cupper Busbar Current Capacity
05/19/2010 7:48 AM
Dear Sir,
Incoming current 10000A from five gas genset and connect a comman CU bus bar. Outgoing 10000A also from that bus bar. What is the bus bar current capacity?
Re: Cupper Busbar Current Capacity
05/19/2010 10:40 AM
Greater than 10000A!
05/20/2010 2:03 AM
Must be greater than 10KA and also depends on short circuit capacity...........
05/24/2010 9:19 AM
It's more complicated than the question you've asked. Rather than in and out, there's 10kA that goes through the bus bar. If there is the potential for a higher fault current, you need to know what the fault current would be. Once you know those parameters, then you can calculate the appropriate bus bar cross-section required to handle the current and have the appropriate temperature rise. Typically, bus bars are designed for a 30degC temp rise from ambient.
Ken Brandmier, Custom Electronics
www.customelec.com
Anonymous Poster (1); Custom Electronics (1); ieshiv (1)
