Previous in Forum: Earth Water - The Source is Inside or Outside   Next in Forum: Gulf of Mexico Oil Leak?
Bendable/Weldable Aluminum
05/19/2010 8:12 AM
Does anyone know of a good grade of bendable/weldable aluminum tubing - here's the catch need approximately 1 1/2" ID with as thin a wall as I can get.
Good Answers: 141
Re: Bendable/Weldable Aluminum
05/19/2010 6:04 PM
A tricky question.
Depending on what you want to do with it, you might consider the type aluminium pipe used for automotive and other AC systems.
In principle, most aluminium, considered, having the right equipment and fill material, is weldable.
For extra soft aluminium it might pose a problem close to the welds, since the composition will result in a more hard area around the weld after time.
Plenty of room here
Reply to Forum Thread
You might be interested in: Plastic Tubing, Rubber Tubing, Tubing
