Previous in Forum: Bendable/Weldable Aluminum   Next in Forum: 32gb USB Memory sticks/Pens - why the huge range of prices.
Gulf of Mexico Oil Leak?
05/19/2010 11:44 AM
If The pipe in the ocean floor is 22" big and has a PSI of 170 000. How manny barrels of oil a day is that?
Re: Gulf of Mexico Oil Leak?
05/19/2010 11:46 AM
It cannot be calculated from the data given.
05/19/2010 12:25 PM
I find it highly unlikely that the pipe is withstanding 170,000 psi. That would require very thick walls, on the order of a tank cannon.
Source please?
Charlie don't surf.
Good Answers: 16
05/19/2010 5:55 PM
Actually the largest diameter of the casing is 36", at the deepest part of the well it is 9 5/8"... The well head system in use on the casing is 18.5".
Where did you get that pressure figure????
Good Answers: 143
05/19/2010 7:04 PM
I might be wrong, but I seem to remember that pipe is 135 000 psi.
But anyway, with the high flow, there's no way you'd get that kind of pressure.
What you do need is this: the pipe diameter; the flow rate (like inches per second); and the percentage of the stream that's oil, not gas. Then you can do the calculation.
PWSlack (1); stevem (1); Tim in Mexico (1); TVP45 (1)
