Previous in Forum: FEA Stress Linearization   Next in Forum: HVAC Lexicon
India - Member - Atul Singla Engineering Fields - Piping Design Engineering - Atul Singla- INDIA Engineering Fields - Mechanical Engineering - New Member
Exchanger Ppiping with Cooling Water
05/20/2010 10:18 AM
In Exchanger piping, with cooling water supply & return lines as inlet and out from channel side of shell & tube exchangers, i have following two doubts :
1. Which end needs to be fixed & which one should be sliding
2. Do we need to put the breakable flange joint??
Atul singla
Good Answers: 61
Re: Exchnager piping with Cooling water
05/20/2010 12:24 PM
1. The "Fixed" saddle needs to be the one closest to the CW risers from underground. If you put the "Fixed" saddle at the other end you could damage and break the risers or the UG headers.
2. No, you do not NEED to install any extra flanges or joints. Don't add cost and don't add potential future leak points.
Do it once and do it right
06/01/2010 4:20 AM
Reason for selecting the FIxed end nearer to the u/g cooling line : to restrict the expansion of the exchnager towards the u/g (natural anchor).
is there any other reason for selecting the fixed end on the u/g lines??
Reason for not providing the breakable flanges : there is already a valve connection so in case of dismantling, we can always disconnect from the valve flange.
Is there any other reason for not providing the breakale joint.
Atul singla
06/01/2010 4:25 AM
Atul singla
Re: Exchanger Ppiping with Cooling Water
06/01/2010 4:17 AM
Atul singla
Register to Reply 4 comments
You might be interested in: Cooling Tunnels, Electronic Cooling Fans
