Previous in Forum: Weigh Too Heavy   Next in Forum: How Do I Change My Forum Name?
Position of a Resolver on a Servo Motor
05/20/2010 2:39 PM
does the position of a resolver matter on a servo motor?. when i move the stator of the resolver it changes my readings on the scopemeter .
Good Answers: 140
Re: Position of a Resolver on a Servo Motor
05/21/2010 4:33 PM
Think of a resolver as a rotary transformer... it has a primary winding, or the "excitation" winding and 1 or more output windings. The phase shift between the input and output windings is normally fixed... rotating the rotor will change the phase shift. It is the measurement of this pahse shift that is used to determin rotational changes.
So... if you hold the rotor and rotate the stator about the rotor, the same effect is present.
http://en.wikipedia.org/wiki/Resolver_(electrical)
Reply to Forum Thread
You might be interested in: Motor Controllers, Servo Valves, Servo Drives
