Previous in Forum: Dual plate check valve   Next in Forum: Valves - Attenuator Function
Valve Class and PN Code
05/21/2010 1:26 AM
How can I define Valve class and PN code of valves?
Suranjan Chattopadhyay
Re: Valves
05/21/2010 2:04 AM
Against the working or design pressure and Temperature you can define Valve Class and at the same time you can get PN for Valve from this class.
For Valve Class Selection check API and ASME/ANSI codes
You might be interested in: Bar Code Scanners, Bar Code Cards, Bar Code Software
