Previous in Forum: Valve Class and PN Code   Next in Forum: turbine
Valves - Attenuator Function
05/21/2010 1:32 AM
What is an attenuator used in valves and how it works? What is the advantages using
such a device in respect of flow pattern, noise and loss of head?
Suranjan Chattopadhyay
Good Answers: 19
Re: Valves - Attenuator Function
05/22/2010 12:05 AM
ACTUATOR you mean. Take it as a motor that is designed to actuate and open/close or modulate the valve via a signal from any controller/switch. Now get a broucher of actuator from your supplier and study it.
You might be interested in: Gas Valves, Industrial Valves, Solenoid Valves
