Previous in Forum: Power Factor Control   Next in Forum: Network Study
13 comments
Power Transformer Vector Group Test
05/23/2010 6:51 AM
How can we test vector group of a power transformer ?
Fakrul
Good Answers: 170
Re: Participant
05/23/2010 7:29 AM
Can you send me a mail thro this forum's mailbox - intimating your mail IDZ so that I can send you a complete write up on Vector Groups & its testing? I am unable to load diagrams in thie forum.
India - Member - New Member Engineering Fields - Electrical Engineering - New Member Technical Fields - Technical Writing - New Member
Re: Participant
05/23/2010 10:06 AM
Hi, Suvo Nababarsha 1417. I've a practical way to check the vector group of a transformer. Consider Primary side phases as R, Y and B and corresponding secondary phases are r, y and b.
1. Short R-r by a copper wire.
2. Now apply 415 V(increase the voltage gradually to limit the current) in between R-Y-B.
3. Now measure voltage as below-
For DY11- VBy= VBb and VYy<VYb
For DY1- VYy= VYb and VBb<VBy
Y-Y or D-D grouping can be detected easily.
ealish macher dam kato ekhon?
Re: Participant
05/24/2010 2:42 AM
Shuvo nobobarso.Thank you for your answer and cooperation.Can we do this by shorting any other terminals.In that case what will be the condition for being Dyn11 &
Dyn1.
apni elish mach pachondo koren.elish mach er dam per kg tay Tk. 500-600 hobey dhakai.
Fakrul
Re: Participant
05/25/2010 1:55 AM
I've given you the example by considering R phase as reference. You can do it by considering any other phase as reference and then you have to measure voltages as I mentioned earlier, but the suffix and prefix of the equations will be different.
As Samad vai told, never apply the voltage in LV winding.
Amader ekhane elish Rs400 taka per Kg.
Re: Participant
05/25/2010 4:29 AM
Thanks for your reply.
Could you please explain this with diagram if we short R-c for Dyn1
Fakrul
Re: Participant
11/13/2010 4:30 AM
hi i am ali khani from iran
please explane me how to test victor group trans test in ynd11 and ynd1 and ynd5 and dyn1
thanks
CR4 Admin: Email address removed. Please do not post email addresses on a public forum. You can register to CR4 and communicate using the private messaging system.
Re: Participant
11/13/2010 11:23 PM
Dear Sidhu
pl. re-check the conditions with vector representation.
I believe the conditions for DY1 and DY11 are interchanged.
For DY1, VBb=VBy and VYy < VYb
For Dy11, VYy=VYb and VBb<VYb.
Biren
Re: Participant
02/21/2011 1:02 AM
For Dyn11
V(Bb)<V(BY) &
V(bY)=V(yY)
Good Answers: 114
Re: Participant
05/23/2010 10:53 PM
You can download image files...
Good Answers: 244
Re: Participant
05/23/2010 11:46 PM
Just supporting Sidhu16:
See this link. It has many testing for transformer, including the vector group (Dy11 and Dy1) testing that Sidhu16 mentioned.
http://electricalandelectronics.org/2008/09/21/power-transformers/ (section 2.4.9: Phasor Group Testing)
Caution: Never apply voltage to the low voltage side.
Shidhu: Apni Bangla Janen?
- MS
Re: Participant
05/24/2010 2:57 AM
Thanks for your nice answer.
Fakrul
Re: Participant
05/25/2010 1:58 AM
Insallah! are Samad vai, apni to Bangali. Ami o Bangali.
When I get praise from you and you support any of my comment then it work as boost up for me.
Thanx a lot.
Sidhu
Re: Participant
01/17/2011 11:46 PM
dear electrical expert can u tell me how to perform the vector group test ,,,i mean how u can get the conditions for different vector groups...i.e dyn11 or dyn1 ...
my mail id is shailesh0508@hotmail.com
Register to Reply 13 comments
Anonymous Poster (4); electricalexpert65 (1); fakrul143 (3); Garthh (1); msamad (1); sidhu16 (3)
