Previous in Forum: Silicon Oil   Next in Forum: Instrumentation Engineer
Sil2 Loop for Shutdown Valve Upgrade
05/24/2010 12:00 AM
Hi, I am working on a project(shutdown valve upgrade) that require a sil 2 loop. given that the control system used is sil 3, solenoid valve used is sil 2, actuator is sil 2 but with a valve that is NOT sil certified, is there any chance that a sil 2 loop can be achieved? Need some basis to argue, i think its not possible since PFD(sys) = PFD(logicsolver) + PFD(sensor) + PFD(final element), and PFD(final element) has the biggest portion. Need your expert advice, thank you very much.
Re: Can this configuration achieve sil2
05/24/2010 2:01 AM
1) You Can Get Failure rates From Your Valve Vendor ,If its reputed manufacturer he may offer
Or
2) You can refer Oreda 2002 From where You can get lamda Dangerous for all types of Valves typically used for ESD , But that data was collected From North Sea area , & may vary depending upon the environment , So You have to Put some note in Your Scoping Paper and Present
Regards
Jose
05/24/2010 3:55 AM
by stating failures rate of valve means the MTBF number right? also, is there a rule of thumb for this; like we refer to the lowest rating in the loop. it doesn't make much sense for me considering having a really reliable control system, good sensors but using a non SIL certified valve. Wouldn't the whole loop be linked together and has the weakest final element. Confused...
Register to Reply 2 comments
