Previous in Forum: Faded Powder Coated Paint of Outdoor Switchgear   Next in Forum: Designing a Crematorium
Aluminum Shapes
05/24/2010 11:30 AM
Dear All:
I am working in a project to fabricate structural & platform in 6061 T6 Aluminum for a Mexican steelmill but I need to buy those profiles for example CHANNEL 8. "I" beams etc.
Any kind of help would be appreciated.
Israel Barron
ibarron@sfmex.com
Israel Barron ibarron@sfmex.com
Good Answers: 204
Re: Aluminum Shapes
05/24/2010 10:57 PM
do you mean to buy CAD profiles? What application or format?
and just for fun... why aluminum?
Chris
Re: Aluminum Shapes
05/25/2010 12:58 AM
There are many stockist of aluminum extruded profiles world wide. It is very likely that exact or near equivalent 6061 T6 profiles available ready stock.[p/]
In the unlikely event of no availability you may be forced to go in for custom extrusion. Custom extrusions however, you will pay for tooling, it will take anywhere from one week (which is very fast) to a month (average) for an extruder to run your parts, and you will be stuck with a minimum production run of one billet (several hundred to a thousand pounds of aluminum).
Google "aluminum extruded profile" is awash with relevant information
Re: Aluminum Shapes
05/25/2010 12:59 AM
Are you interested in buying Aluminium Profiles ? As we are manufacturer , we can supply you. Please give details. Thanx
Re: Aluminum Shapes
05/25/2010 10:58 AM
Dear Sunil
Give your e-mail and I will send all the information related for it.
Hobbies - DIY Welding - pipewelder
Re: Aluminum Shapes
05/28/2010 8:56 AM
Something don't sound right about aluminum platform in a steel mill. what size aluminum I beam and channels do you need? stuff like 2,3,4,6 and 8 inch C-channel, angle, heavy, tread plate and sheet I and H beams, square and round tubing solid bar stock and piping should be readily available but it will be very expensive. I find when dealing with aluminum section sand shapes that the usual thickness is about twice that of the same size in steel material. If it was me and I was set on making it work with aluminum I would frame it issuing steel and attach 5/16 " thick tread plate to it along with aluminum or painted steel hand rails. No one would know it had a steel frame underneath the platform although a steel frame will make the structure very strong and ridgid.
pipewelder
Re: Aluminum Shapes
05/28/2010 12:26 PM
Could you pls give details
Sunil
sunil@ultrabearings.com
Register to Reply 6 comments
chrisg288 (1); Israel (1); krishnan.ng (1); pipewelder (1); sunil2008 (2)
