Previous in Forum: can the robot be in love??   Next in Forum: magnetic field
gear use in cement plant
02/17/2007 1:25 PM
please describe gear use in p cement plant for various machine
Re: gear use in cement plant
02/17/2007 11:19 PM
"please describe gear use in p cement plant for various machine"
Do you mean the ring gear on the rotary cement kiln and it's drive pinion?
Heavy duty spur and pinion AFAIK. Other machinery much the same, nothing exotic.
Perhaps a kiln specialist will have something more definitive.
01/10/2008 2:17 AM
try to look a little around here - http://www.flsmidth.com/FLSmidth/English/Contact/Brochures+and+info/Brochures/Kilns+and+Firing/default.htm
you might find something on the topic there
02/19/2007 8:49 AM
You need to be a bit more specific - Ae you looking at Girth gear for kiln drives or symetro gears for Raw mills and Cement mills? or just general drive systems associated with Cement plants?
Register to Reply 3 comments
PK (1); Stirling Stan (1); Triton67 (1)
