Dear All,
We have a turning gear motor of 22KW and 1500 RPM on the Steam Turbine. There are two supplies for this motor. One is from the Government Source and the other is back-up from the 1MW generator. When we run this motor on Government Source it runs normally taking only 18A load but when it is switched to 1MW Generator supply. It trips on overload after 5 sec. We measured the voltages at each terminal these are 380V L-L. We also checked the frequency. this is constant 50 Hz at yellow terminal of the generator supply while other terminals show varying frequency between 50 to 70 Hz. Also an abnormal sound comes from generator whenever the motor load is shifted.
