Previous in Forum: Spitfire - Efficiency of Cooling and Thrust   Next in Forum: Why Has No One Thought of This or Where do I Purchase . . .
23 comments
Motors and Pool Pumps
05/25/2010 10:17 AM
I am not an Engineer but have a question regarding motors for pool pumps. I am an Environmental Public Health Professional. One of my duties is to inspect public pools in my county in Ohio. One of the things I check is to see if equipment has been replaced and make sure it is the correct equipment and that the operator has completed a replacement notification form. They don't have to do this if they are simply changing like for like.
My question is, If they replace a motor that powers a pump with a motor of the same horsepower is it the same, like for like? Or do motors of the same horsepower potentially have different characteristics such as rotation rate that would affect the output of the pump and therefore change the flow rate/turnover rate of the pool?
Thanks for any responses. Bill VanCuran R.S.
Re: Motors and pool pumps
05/25/2010 10:39 AM
Well, I'd say they are like for like. A 1 HP motor will produce 1 HP. There may be subtle differences in power consumption, but that's about it.
Here in the USA motors run at 1700 RPM or 3,450 RPM. Most pool pumps run at 3450 RPM. You would want the replacement motor to run at the same speed as the junk motor. This is usually a no brainer for the pump repairman.
No report required.
05/25/2010 6:48 PM
When comparing the motors the power delivered will depends on the loading on the motors and rotational speed. As suggested, a 1 HP motor can deliver 1 HP at specific rotational speed and load. So you must verify the rotational speed rating of the pump motor, since the pumping capacity will depend on the rotational speed at which the pump is operated. Motors tend to vary somewhat also, and their are varying efficiencies at which the transfer power to a pump. I would say if it is the same manufacturer and model number it is like for like, else they need to supplied the motor efficiencies and curves to show equivalence or better to standards.
05/25/2010 6:53 PM
The OP seems to me to be concerned about motor speed and the effect on turnover.
I assume that you will concur that the motor will run at 3450 RPM.
We assume that a competent pool servicer will replace the motor like for like.
Thanks.
05/25/2010 7:18 PM
And this is why they must provide paperwork, to show the service was condcuted by someone competent and who performed a proper job. I would never allow a well pump or motor to be replaced with out proper documentation on the replacement showing it conforms to project requirements. BTW, pump motors tend to be 1700 and 3450, and 1100, but a closer inspection of the power curves would allow you to see they aren't actually exactly 1700, sometimes they are set to perform at 1850 rpms. Also, the pump needs to deliver pumping HP to the water to achieve turn over rates.
Good Answers: 61
05/26/2010 10:36 AM
Lynlynch,
There is a flaw in your reasoning: "competent pump repairman". You cannot assume the competence of the person doing the work. The purpose of the OP's job is to verify that the work was done in a way which will not compromise public safety, sanitation and health. Many municipal pools use their own employees to do this kind of work. Places like the YMCA or a health club may have the custodian or a handyman do it. The managers usually have no clue whether or not their staff is capable of this type of work.
Case in point: several years ago the local YMCA upgraded their aquatic center. After replacing 3 brand new pump motors, the service tech asked our utility if we could raise the voltage to the building. The service is 208V, and he had burned up three 240V motors, each time causing a building evacuation and fire response. He seemed incapable of understanding that he needed a 208V motor, or that raising the voltage would damage all of the other equipment which was properly rated. One of my staff finally took pity and walked him through ordering the correct motor.
05/26/2010 2:15 AM
How do you get the motor to not run at standard speed?
Good Answers: 117
05/26/2010 4:49 AM
change the frequency
05/26/2010 6:28 AM
Then you are using a VVFD that isn't mentioned. İ would think they would be rare for pool pumps as well.
Good Answers: 117
05/26/2010 6:48 AM
I will repeat myself in answer to your question.
To get/have a motor NOT run at a standard speed, you can use a Variable Speed Drive.
Now do they use VSD's for speed control of pool pumps in this particular application that the OP mentions? Who knows!
I know of several pools in the UK & Canada that do, their application is to increase the circulation of the water dependent on several factors and to make waves.
But this is off topic
Reply Score 1 for Off Topic
05/26/2010 11:13 AM
Standard speeds vary. I just did a quick search online and found motors for pool pumps in the Us that run at 1800, 1700, 3450 and 3600. That was just looking at 2 manufacturers sites and reviewing the specifications. Plus if you look they allow a variance in thats standard speed for the motor. So some actually run at 1850 instead of 1800. Plus there are other electric motors you can purchase for pumps that operate at 1100 or 1200. There really isn't one standard, just some more commonly used speeds.
05/26/2010 11:42 AM
Please - The electrical frequency and number of poles set the motor speed. One of the electrical guys can possibly explain this to you. Or can you find a fixed speed motor running on 60 Hz at 1400 RPM?
05/26/2010 11:58 AM
I have not seen a 1400 RPM motor as I can recall, just the ones i looked up really quick at a couple of manufacturers websites. The bearings and other components set a load internal which impacts the efficiency. Just the fact that there are manufacturers showing other standard operating speeds for just pool pump motors in the US, should indicate the two operating speed of 1700 and 3450 are not standard.
05/25/2010 5:41 PM
Like LynLynch says, The Pool motor pumps I see operate at 3450 RPM. As they are powered by induction motors the armature speed is determined by the frequency of the AC current powering it. So generally you will see speeds of 1725 or 3450. Ideally it would be 1800 or 3600, but there is some slip. The pumps are centrifugal, so you need good rotor speed at the impeller to push water through a filter. Some smaller spas have two speed motors to maintain flow through the heater when not in use, but that is not common in swimming pools. If they have changed the pump motor then I imagine they have replaced it with one of the same RPM. They would almost have to go out of their way to find one with the wrong speed to fit the pump. As the speed would probably be half what it should be, the sound of the pump would be immediately and noticeably different. -Illya
05/26/2010 12:03 AM
Yes. A 1 hp 1725 rpm motor will not pump the same volume as a 1 hp 3450 rpm motor. If both speed and hp are the same, then the motors could be considered "like for like".
Si hoc signum legere potes, operis boni in rebus Latinis alacribus et fructuosis potiri potes!
Good Answers: 117
05/26/2010 4:32 AM
Depending on how many pools you have to inspect, and how good the maintenance of the pools has been before you started as the Pool inspector, you might ask at each pool if they have a maintenance log book, and a general equipment layout/plan/plant design (is there a maintenance man?). I would guess that as you work for the local authorities, then the pools were built by the local city council and therefore designs/layouts/equipment installed will be part of public record. I 'm sure that someone could help you understand those plans
If those plans are available either in the records department or at the pools, it might tell you what type/size of motors are currently in use, that is, the HP of motors and any other information that you require.
The maintenance log book might tell you when motors/valves were changed etc.
If no log book, then start a maintenance log book AND maintenance work sheets so you can keep a record of what work has been done, when it was completed and what was repaired/replaced.
If there is a maintenance man or department or even the pool manager, then it can be their responsibility to keep the log updated, it would not be difficult or complicated
05/26/2010 7:52 AM
Here we go again. Instead of providing a simple answer to a simple question, you geniuses have to go out of your way to prove your superior intelligence and vast knowledge of any subject that comes along.
For example, " 1700 and 3450, and 1100, but a closer inspection of the power curves would allow"
Or, "I would guess that as you work for the local authorities, then the pools were built by the local city council and therefore designs/layouts/equipment installed will be part of public record."
"To get/have a motor NOT run at a standard speed, you can use a Variable Speed Drive."
The poor OP couldn't care less about VFD's or the local city council.
Get over it people! I cannot believe the egos here. You are not helping the guy, you're just confusing the issue in your zeal to be recognized as the world's smartest person.
Good Answers: 117
05/26/2010 8:37 AM
and you've only added to it all, so who now needs to get over ones self.
I do agree with you that many people read these posting and get all excited in their rush to prove themselves "smart".
However I do think that many people DO NOT read the posting and DO NOT answer the question.
MY answer to the question, "how does a motor not run at a standard speed:" was simple and in reply to another question NOT the OP, my second reply to make it clear to the person who asked was to clarify my reply.... NOTHING to do with the OP.
Now if you are as clever as you think you are then you will read my FIRST submission, that if the OP needs to know what size of equipment is installed then he can easily find it, How the hell is that confusing? Unless you actually think the OP is moron!
I would say you in your rush to be the "Mentor of all" have done more damage.
This forum is for all, that means you will get those who know a lot less than others, some will know nothing at all, but want to learn, and those who are trying to show-off that they do know something about everything, but in fact they really know nothing at all.
BUT, it's open to all therefore you have to put up with the egos and the not so smart and the really dumb, and the really, really thick.
Before you start trying to be-little those that offer in this open forum... try reading AND understanding who has replied to who and what they are talking about.
Please remember that no-one know everything, but in all those posting, there may be one or two gems that you or me or anyone who reads these postings can take away.
Reply Off Topic (Score 6)
05/26/2010 9:26 AM
Everything after the second post is BS and chest beating and contributes nothing to clarify or add to the discussion.
Good Answers: 117
05/26/2010 10:26 AM
so why bother telling us something we already know... and after you with the chest beating!
05/26/2010 12:19 PM
This is how you find out who uis an actual working engineer and who is a technician or contractor. Engineers always require inspections and records vaerification, which is what the OP was required to do unless they show a replacement of like for like, which would indicate same manufacturer and same or equivalent model set at the same performance requirement. The contractors always believe any inspection is jsut someone picking at their minor flaws, until something fails and they are under threat of a law suit for millions $. Technicians don't generally believe in inspection for a similar reason, but they are never under threat themselves of a law suit, so they are always much more adamant about no need for inspection or records keeping/audits.
It is just a better practice if the ordinance allows to actually verify the replacement, and not go off some technicians hearsay BS about how there is no chance of anything being non-conforming, because he knows it from working experience or such.
I once had a striper try to tell me that his striping was correct because he measured it accurately from a a fixed object (which turned out to be an old stripe that was to be removed and varied) shown on the plans (which was to be removed and never accurately surveyed). It looked odd and one lane appeared too narrow. We had him measure from the face of curb to verify and he took his wheel and came back and told us the correct measurements for the lane as he marked. Later when cars were allowed in we could see how narrow it was and I personnally went out and measured the striping, it was over 3 feet narrower than the striper told us. All of a sudden that guys was somewhere in southern Californaia, and we had soem manager in the Bay Area to talk to, then that guys was gone after he promised to repair the mistake and we got a new manager from Stockton to talk to who wanted to fight the issue looking for shared liability. You always verify work when done by a technician or contractor, just the thought of it keeps them honest. Recently, i poured some concrete and the concrete supplier is notorious for delivering load that are too wet and crack, when not being inspected (so architectural, non structural applications). So having experienced this behavior amongst a number of suppliers in the past I already knew that if I told them I woudl be inspecting and sampling the load and supplied them a specification for the concrete, I would receive a good load of concrete. My contractor was really concerned about the quality of the concrete from this supplier, but surprise when the load arrived it was at a good water:cement ratio (better than the 3 inch slump i had asked for and slightly less water than i had calculated) and the first thing the driver asked about was if the load was being sampled. It just keeps them honest to let them know that there is some inspection process. Otherwise technicians will typically do first whatever requires the least effort on their part and second what is the cheapest alternative (contractors do this in opposite order usually) with quality being an after thought as long as it isn't visually apparent or likely to fail within the warranty period.
05/26/2010 10:39 AM
Here in the UK we have a pump manufacturer ( GRUNDFOSS) that supply pumps with three different speed settings. These speed settings are for adjustments to the pipe sizes being used. For instance if the pump speed is to fast through a small sized pipe then you will get a situation of water heating inside the pump and causing bubbles to be generated and in turn causes wear on the inside of the pump known as wiring.(spiraled lines) coming from the impeller on the pump body. this in turn will also wear out the pipe work and fittings more quickly. So when fitting a new pump the operating pressure and pump speed should be checked for the right amount of pump lift,(How far up a pipe the water will be raised before it will no longer be raised by the pump).
I would suggest to you to look at the pipe work to locate any pressure gauges and any pressure reducing valves (PRV's). Once you have located these items look for any lines that may have been drawn on them to see if the gauge needle still is within its operating limits. It is a bit of a hit or miss situation when you are only on the premises for about an hour to know what you are ment to be looking for. Even if a pump has been changed like for like it dose not mean that it has been setup correctly.
But that is not realy your responsability?. If you are going that far into the work that has been carried out you will need to have flow charts and pressure reading being made before and after the work is implimented.
Good Answers: 97
Re: Motors and Pool Pumps
05/26/2010 5:07 PM
While correct replacement is important, what makes me nervous about public pools/water features, is correct wiring methods.
CRTL-Z
Good Answers: 128
05/26/2010 10:18 PM
Mr VanCuran,
Typical swimming pool pumps use a motor that is with a "C face"--in other words, it has a flat end with a machined rib and bolt holes to allow its connection directly to the pump. I consider three factors being required to rate the replacement as being " like for like":
  1. Same horsepower.
  2. Same or higher service factor.
  3. Same or nearly same speed (such as 1700 or 1725 or 1740 or 1750 RPM, meaning a speed difference less than 5%).
I believe the original documentation filed when the pool was permitted and built should give the first motor's data. The nameplate information would give the second one. If any of the three items I listed above fail, then I would agree that the entire application needs proper design review because it is a modification from the original design.
If it is the installation of an entirely new pump and motor, then I could agree with insisting on filing the necessary paperwork (pump curves, and flow calculations) for the pool to be approved as meeting the requirements for turnover rate, etc.
--JMM
Reply to Forum Thread 23 comments
Anonymous Poster (1); brich (5); illya Leonov (1); jmueller (1); lyn (4); MoronicBumble (1); pwr2thepeople (1); RCE (5); russ123 (3); Unredundant (1)
You might be interested in: DC Motors, Stepper Motors, AC Motors
