Dear Sir,
In 1 1/4 Cr-1/2 Mo material J factor is not required, While in case of 2 1/4 Cr-1Mo material J factor is required to calculate. Can you explain me why J factor is required? What is impact on material with consideration of J factor? Why J Factor is not calculated for 1 1/4Cr-1/2 Mo material? What is the effect of J factor on material mechanical properties?
