Previous in Forum: Project Ideas   Next in Forum: J Factor
Tramp Iron R emoval from Conveyor
05/26/2010 5:44 AM
Does anyone have creative ways of removing tramp iron from a coal conveyor, other than the traditional overhead magnet and under conveyor metal detector ?
Has there been anything new on the market ?
Re: Tramp Iron Removal from Conveyor
05/27/2010 6:57 AM
Why deviate from the simplest ($$$) method to remove these metal problems???
If it isn't broke, why fix it???
Knowledge Gained is in Direct Proportion to Equipment Ruined... or, K(+) = E(-)
Engineering Fields - Civil Engineering - Member Engineering Fields - Construction Engineering - Member Engineering Fields - Mining Engineering - Member United States - Member - Member Popular Science - Weaponology - Member Hobbies - Target Shooting - Member Hobbies - Car Customizing - Member
Re: Tramp Iron R removal from Conveyor
05/27/2010 8:43 AM
There are other more expensive and less effective methods. But why? Isn't the concept to make more money, not spend more?
You cannot escape the responsibility of tomorrow by evading it today - Abraham Lincoln
05/27/2010 8:46 AM
This is certainly not a new method but I like using a magnetic head wheel. The good material goes over the head wheel and down the product chute. The magnetic stuff hangs on the head wheel a little longer and goes down a chute just under the conveyor. The magnetic material is released as the belt separates from the magnetic head wheel on the bottom of the conveyor.
This method works best when material is evenly deposited on the conveyor belt and not to deep for the magnet to "reach".
Everything I know about opera I learned from Bugs Bunny
07/09/2010 2:33 AM
That system would work except that coal conveyors are fitted with head pulley scrapers and 2 or 3 return scrapers that would discharge the metal into the coal product chute. The scrapers would be destroyed.
Mechanical Solutions Company where 'There is no such thing as a PROBLEM, just an ISSUE requiring a SOLUTION'.
Register to Reply 4 comments
DaveB (1); Old Coal Man (1); tecmate (1); Who Wants 2 Know??? (1)
You might be interested in: Magnet Wire, Conveyor Controls and Monitors
