Previous in Forum: Ceramic Coatings   Next in Forum: What Chemical Reaction Results in Implosion?
9 comments
SS 202
05/26/2010 2:57 PM
Is SS202 magnetic steel ??
Good Answers: 299
Re: SS 202
05/26/2010 3:50 PM
Hello, nilayveera. How is the electrical lug manufacturing business these days?
SS202, eh? Can you tell us if it is austenitic?
Re: SS 202
05/26/2010 6:03 PM
Well my Machinery's Handbook - 22nd edition page 2104 would say yes its austenitic.
and my Introduction to Phyiscal Metalurgy - second edition Page 371 states that these types of Stainless steels is essentially nonmagnetic.
But cold working, it can develop a wide range of mechanical properties and can become slightly magnetic. And on page 373 it states its general purposelow nickel equivalent of 302; Ni partial replaced by Mn.
I believe some ss bolts are made from 202 or 302 SS
So basically, yes it can be. not knowing any other information of this material.
p911
he's lucky I had to look for simular stuff last week
Re: SS 202
05/27/2010 1:25 AM
salam allikum,
it is known that austenitic stainless steel is non-magnetic.
Herein below the physical and chemical properties for this material
AISI Type 202
Category
Steel
Class
Stainless steel
Type
Austenitic standard
Common Names
Chromium-Manganese-Nickel steel
Designations
United States: ASTM A276 , ASTM A314 , ASTM A412 , ASTM A429 , ASTM A473 , ASTM A666 , FED QQ-S-763 , FED QQ-S-766 , FED STD-66 , SAE 30202 , SAE J405 (30202) , UNS S20200
Composition
Element
Weight %
C
0.15
Mn
7.5-10.0
Si
1.00
Cr
17.0-19.0
Ni
4.0-6.0
P
0.06
S
0.03
N
0.25
Mechanical Properties
Properties
Conditions
T (°C)
Treatment
Density (×1000 kg/m3)
7.8
25
Poisson's Ratio
0.27-0.30
25
Elastic Modulus (GPa)
190-210
25
Tensile Strength (Mpa)
515
25
annealed (sheet, strip)
more
Yield Strength (Mpa)
275
Elongation (%)
40
Reduction in Area (%)
Thermal Properties
Properties
Conditions
T (°C)
Treatment
Thermal Expansion (10-6/ºC)
17.5
0-100 more
Thermal Conductivity (W/m-K)
16.2
100 more
Specific Heat (J/kg-K)
500
0-100
Electric Properties
Properties
Conditions
T (°C)
Treatment
Electric Resistivity (10-9W-m)
690
25
QA/QC ENG.: AMR SOLIMAN
PETROJET
EGYPT
Re: SS 202
05/27/2010 4:34 AM
Good day, salam allikum
Your statement
Sounds like a definite answer, considering nilayveera asked a vague question without any accompanying information, that could be answer differently.
Or should I say a vague/typical answer to a vague/typical question would be more fitting.
Should have nilayveera put a magnet to it.
p911
Good Answers: 299
Re: SS 202
05/27/2010 10:31 AM
Hello P911.
Agreed. Exactly why my response was worded as it was. I see no sense doing all of the homework for someone... let him think about it a little, and he might be able to reason it out, or can find the answer in a textbook.
Re: SS 202
05/27/2010 11:43 AM
I would normally be the same way, It was just that I just did some research on this very thing on a project I was doing about a week ago.
Info is out there.
Re: SS 202
05/27/2010 7:58 PM
the pratical experince is, SS 202 has properties to rust in long run. We want to use this steel in a part of electrical transformer so am concerned with the magnetism.
i did not by any means find this simple question vague.
Re: SS 202
05/28/2010 7:43 AM
Hello nilayveera:
Problem was it was too simple. And to me it would be vague, you are asking for a definite yes/no answer to a question that could have a number of possibilities. As I stating in the earlier post it seems that it would depend on how the material is worked. with the heat sheet or mill spec. it would help.
And as the guest stated it was a definite answer and I disagree with that from my post which I listed my reference, that answer should not be definite with out more information of the material. Do you have heat sheets with that?
And since it does oxidize it may have ferrite in it to be magnetic. They use that because of reduce galling. Tensile strength is reduced, but so is the facturability of the material.
Did you put a magnet on it?
In the mean time I'll look through my references to see if I can come out with a more definite answer, but with out more info, I can't gaurantee.....
p911
Re: SS 202
05/31/2010 2:19 PM
Nice links, but thats why it reenforces the reason you need the heat sheet or mill spec papers, page 5 on your last link shows Fe. As well as other aloys replaceing Ni due to the shortages.
Register to Reply 9 comments
Anonymous Poster (1); Doorman (2); nilayveera (1); phoenix911 (5)
