Previous in Forum: GPS/pull sensor   Next in Forum: Pulse Circuit Needed
Use of Matched Transistors
05/26/2010 5:48 PM
I have seen that matched transistors are used in diff. amplifier ckts and in some others,
but are there any use of it for high i/p impedance?
if there are any, can you please help me saying name of that/those particular ckts?
Good Answers: 119
Re: Use of matched transistors
05/27/2010 2:43 AM
Most integrated circuit amplifiers have inherently matched input devices because all the circuit elements are developed on a single die in the same process. For special amplifiers, input devices "may" be trimmed prior to final packaging or external trim pin(s) may be included in the final packaging.
For high input impedance, see Bi-FET input op-amps like...
http://www.frc.utexas.edu/page11/files/AD745.pdf
and CMOS op-amps like...
http://focus.ti.com/lit/ds/symlink/opa2334.pdf
Many more out there if you take the time to search for them. This really looks like a homework question, so I'm done on this topic.
Re: Use of Matched Transistors
05/28/2010 8:38 PM
Back a few years ago, 34 to be exact, I worked for a major smoke detector manufacturer. We used the CA4007, a commercial CMOS device with uncommitted transistors, for a front-end. Chamber currents in that smoke detector were on the shy side of 20 pA (0.000,000,000,020 amperes). We needed to measure without disturbing. Check out the U.S. patent - 4,138,664. Yes, matched FET's are very useful in electrometer applications.
QL
"When in doubt - check it out!"
Register to Reply 2 comments
You might be interested in: Amplifier and Comparator Chips
