Previous in Forum: Current Reduction if the VFD is Connected to Motor   Next in Forum: Old Ballast (2x) for Metal Halide 1000W Application
Earthing & System Grounding
05/31/2010 4:21 PM
1)How do we provide protection against indirect lightning surge?
2) Why do we use reactance earthing for nuclear TG?
3) Why GI pipes are used for the pipe electrodes?
Re: Earthing & System Grounding
06/01/2010 3:49 AM
<...provide protection against indirect lightning surge?...>
Overhead telegraph wires used to have surge arrestors installed between line and ground so as to provide a discharge path for high voltages that appear on the line. From memory, these were a small glass discharge tube fitted with two electrodes, each one with a connection lug outside it. The lugs bolt onto a terminal block, with the earth connection one side and the lines' connections the other.
The other technique used to protect things is the common-or-garden lightning spike, fixed to the top of a tall structure such as a mast or a tall chimney. The technique involves attracting the lightning preferentially to that spike and then to earth, thereby reducing the risk of its striking adjacent structures.
