Previous in Forum: Pipe Schedule   Next in Forum: How to Verify Ovality of a Large Thin Horizontal Vessel?
Difference Between Engines
06/01/2010 9:38 AM
Dear,
1.What is the difference between IC engine & Gas engines?
2. What is the measuring unit of knocking?
Thanks.
Good Answers: 58
Re: diff bet'n engines
06/01/2010 10:06 AM
1. If the acronym you used, "IC" stands for "Internal Combustion" then there is no difference between an "IC engine" and a "Gas engine", they are both internal combustion engines.
2. If your term "knocking" refers to "pre-ignition ping" then this web site http://en.wikipedia.org/wiki/Octane_rating should be of some help.
These questions have a slight feel of home work to me. If this is home work the first answer is on me, you will have to do some reading on your own for the second answer.
Good Luck!
Hobbies - Automotive Performance - New Member Hobbies - CNC - New Member
06/01/2010 6:37 PM
There is no "unit of measurement of knocking" per se. But if you do some reading for your homework, you will find it has a lot to do with ignition timing among many other factors.
It is better to fail in originality than to succeed in imitation.
06/02/2010 7:56 AM
I think he wants something to do with octane number.
Re: Difference Between Engines
06/02/2010 12:27 PM
The octane number rates the fuel, not the engine.
Register to Reply 4 comments
Anonymous Poster (1); Economist (2); KJK/USA (1)
