Previous in Forum: Difference Between Engines   Next in Forum: Flow Rate In a Pipe At 170 Bar
How to Verify Ovality of a Large Thin Horizontal Vessel?
06/01/2010 10:31 AM
Hi all,
I just want some opinion about the vessel that I currently design.
The ID is 9000mm and T.L-T.L is 38500mm and the min thk due to internal pressure is 24mm. Additional info is D.T is about 315°C and D.P is 0.575 N/mm2.
Since the vessel will be supported by two saddle and there is no external/internal stiffening ring due to zero external pressure, I am worry that due to weight of the vessel itself , the bending stress at the mid span and also at the horn of the saddle might make cylindrical shape of the vessel became oval and that is something I really want to avoid.
I already perform some manual calculation as BS 5500 Annex G and Zick study but both of them just show the stress but not the indication of change in shape for the vessel.
I am looking for some suggestion on how to approach this matter, do I need to perform modelling or someone has some formula to verify this situation.
thanks and have a good day
rise and rise again...continue to learn is nothing wrong
Re: How to Verify Ovality of a Large Thin Horizontal Vessel?
06/01/2010 11:10 PM
You can proceed such a design for two saddle supports using any method, but you have to check for stresses in vessel due to those two saddles using ZICK's Method.
• See this file, and note the serious effect of dimension A (distance between saddle support and T.L): Design_of_two Saddle_Supports for a Pressure Vessel.
• Or see the whole design of a pressure vessel as per ASME code, Section VIII, Div. 1: Pressure_Vessel_Design_Calculations per ASME VIII, Div.1.
06/02/2010 5:57 PM
• With respect to the permissible and acceptance criteria of ovality (out-of-roundness) for cylindrical, conical, and spherical shells, as per ASME code, Section VIII, Div. 1, see Para. UG-80 :
a. At any cross section (including head-to-shell junctions): Dmax. - Dmin. ≤ 1 % D
b. When the cross section passes through an opening: Dmax. - Dmin. ≤ 2 % D
Where,
Dmax. = Max. inside diameter of shell
Dmin. = Min. inside diameter of shell
D = Shell nominal diameter at the cross section under consideration
• See link for UG-80__Out_of_Roundness_as_per ASME VIII, Div.1.
10/31/2011 2:40 AM
Dear Sir
How this out of roundness in calculated in Div 2. Is there any graph for the same like in div1.
Regards
Vgsh
vgsh
11/05/2011 4:12 AM
Sorry, I am not interesting at Div. 2.
06/04/2010 4:33 PM
thanks so much for the reply mr.abdel
now i am more clear about the method and hopefully the vessel is not going to be out of roundness....
Abdel Halim Galala (3); wijeesh (1); zhafir (1)
