Previous in Forum: Suction Spools   Next in Forum: Filler Wire
9 comments
Stiffener Joints
06/02/2010 12:19 AM
We make Kitchen Equipment like Table Tops, storage racks etc., and we were using silicon to join the stiffener in the bottom of table top for sound deadening. I want to know if there is any solution to join stiffener in the bottom of table top with lesser cost than silicon. We can't do welding in stiffener because welding make quality problems.
Ravi.
Re: Stiffener Joints
06/02/2010 11:15 AM
It is pretty fundmental for us to know the materials in question.
06/02/2010 8:25 PM
"and we were using silicon to join the stiffener"
I think you mean silicone.
Epoxy, glass fiber reinforced epoxy, urethane, acrylic, solder can all be used.
Really, all four of your questions have no specificity.
Good luck.
06/02/2010 10:50 PM
You could try stud welding and screw it in place. (depends on materials of course)
06/02/2010 11:11 PM
Check out coating materials from these guys: http://www.seriousmaterials.com/
Vince
"There is nothing more difficult to plan, more doubtful of success, nor more dangerous to manage than the creation of a new order of things." - Niccolo' Machiavelli
06/02/2010 11:40 PM
Which do you want to make, cheap products or quality products?
06/03/2010 12:25 AM
I would have thought silicone ahdesive would be the easy and cheapest method.
Good Answers: 120
06/03/2010 4:15 AM
what he needs is a resilient filler. Silicone fills the gap and cures to a soft rubbery mass.
A hot melt glue is cheap and will fill the gap and deaden the sound transmitted and cools to about the same physical form....very quickly, and it can be parted with a hot air gun if needed. Another method is contact cement and another is foamed stud adhesive, both of chich will fill the gap but are more permanent. A few tests should see what works for you.
Per Ardua Ad Astra
Engineering Fields - Civil Engineering - New Member United States - Member - New Member
Location: The most variable and beautiful State in the U.S. - And the worst managed and least livable one too.
06/03/2010 10:42 AM
I recently 'rebuilt' multiple stainless steel restaurant style tables to handle higher loads.
The original manufacturer had used a thin foam type two-sided tape that was working very well for this purpose. It was a pain to remove!
Highly educated by life, books, and institutions. In that order. The Man denies me the big E title 'til I bow before him, cash in my outstretched hands and 'tests' sticking out my A%#. I bestow my own title: Engineering 'Technician' Extraordinaire!
06/05/2010 11:56 PM
There is a website, www.thistothat.com, which should offer some advice about which adhesive works best.
Lehman57
Register to Reply 9 comments
aurizon (1); dkwarner (1); garth (1); Lehman57 (1); lyn (1); Smeaton (1); uncommon (1); user-deleted-1105 (1); Vince GEntile (1)
