Previous in Forum: Gutter Over Flow   Next in Forum: Oil Degradation in Sea Water
Helium Leak Test
06/03/2010 12:23 PM
when helium leak test is done in valves.
Re: Helium Leak Test
06/04/2010 8:03 AM
...valves end up with high-pitched, funny voices.
http://www.youtube.com/watch?v=d-XbjFn3aqE&feature=related
06/04/2010 8:22 AM
The test I am familiar with is for a vacuum leak in a condenser, The helium is injected in suspect areas and the vent from the air ejector is monitored for the helium. This application is fairly straight forward because the outlet ultimately has to be the vent.
You could also use this test in other systems by charging the system and sampling the various valves and components of the system. The drawback would be that the helium could be in many places, soap suds could be as effective.
In a single valve you could test for packing leakage directly, testing the valve in a system will depend on the configuration.
If you fail to follow through, you will fail.
Register to Reply 2 comments
