Previous in Forum: Diesel Generator sets   Next in Forum: 150 lb Pipe Rating
ID Fan Damper Controls
06/03/2010 1:10 PM
We have a ID Fan on a 750MW coal plant for the FGD system that is controlled by a DCS system for the opening and closing of dampers for air flow based on the boiler. Some think that ID fan damper contols IVC linkage should have a mechanical characterization rather than DCS.
Any history?
Re: ID Fan Damper Controls
06/05/2010 8:54 AM
Well, as long as this post is all about PP acronyms:
You really should consider DCS-controlled VFD for not only the ID but any FD fans as well. You'll get much better flow with less over-all pressure drop across the system. An inch or millimeter saved here or there could reduce the parasitic load of the plant significantly. On a 750MW dirt-burner such as yours. the savings would be considerable.
04/30/2011 7:21 AM
Sir we are using an actuator for inlet damper of ID fan
the actuator is 3 phase motorized intelligent damper actuator which is a chinese make
it is electronic actuator
starting it was working fine later it made lot of problems
so please suggest equivalent indian make damper actuator
thanks in advance
