Previous in Forum: why neutral earthing is required for DG.   Next in Forum: Changes Required in Switchgear When Load Increased
Transformers
06/04/2010 9:36 AM
How to know balance and unbalance load of the transformer?
Re: Contractor
06/04/2010 9:43 AM
Connected single phase loads are unbalanced
Three phase loads are balanced.
Re: Transformers
06/04/2010 11:56 AM
weight the loads, you know then it is balanced or unbalanced.
Re: Transformers
06/05/2010 1:49 AM
Dear Sir,
Load balancing is Ok, but Unbalancing - for what purpose ?. First make a
list of all loads & split them into 3 Phase loads & single phase loads. Take out the
single phase loads and group them so that you can get equal current in each
phase. Surely there will be some unbalanced current which will flow through the
neutral ( 5 % will be admissable). This will a crude method as it takes no power
factor into account for each single phase load. But this method works out fairly
well.
Manroop.Chennai.
Re: Transformers
06/05/2010 7:03 AM
No. He wants to know the load(weight) at each legs are how balanced or unbalanced. He well educated in the electrical load balancing.
Good Answers: 170
Re: Transformers
06/08/2010 9:46 AM
Just split distribution of the total single phase loads equally amonst the three phases does not ensure that all the three phases would be loaded equally. There is always the factor of utilisation.
Also, where from did you get the 5% "admissible" neutral current? Why not more? Can you trace it back to any National and/or International Standards?
Anonymous Poster (3); electricalexpert65 (1); manroop (1)
You might be interested in: Transformers, Power Transformers, Telecom Transformers
