Previous in Forum: thermal engineering book   Next in Forum: Hydraulic Diagram for Polar 115 ce Cutting Machine
Pressure Inside a Paper Roll
06/04/2010 3:05 PM
We are looking to simulate print offset in a rewound paper roll. But to know what pressure(force) to use on the offset test we need to understand what kinds of pressures are present inside the roll.
From what I've been able to reason is that these pressures are going to be directly proportional to the amount of tension applied while winding. It should also be inversely proportional to the radius. So as tension increases on the paper, pressure inside the paper should increase. As the roll grows bigger, pressure inside the roll should decrease, being higher towards the center and lower at the edges.
Does anyone know of any models to predict this or how to calculate it? Force balances in radial directions perplex me.
Thanks
Re: Pressure inside a paper roll
06/04/2010 3:53 PM
Hello UoDChemE02,
For most applications, you want the pressure at the core and the outside of the roll to be the same. This is achieved by a tension taper function as the roll is wound. Some winders use torque to achieve a "natural" taper. In more precision winding, the amount of taper is determined using feedback from the load cells with an algorithm. If you do not decrease the tension enough as you are winding the roll, the pressure at the core will increase with successive winds and you may crush the core.
This is extremely difficult to calculate because, not only do you have tension to take into account, but the friction of the web material to itself and it's elasticity.
If your winder has a taper function that can be adjusted, the best solution I can see would be to generate some data by running some trials. The tension in these rolls can be measured using pressure-sensitive films. See the following sources (disclaimer):
http://www.sensorprod.com/index.php
http://www.tekscan.com/pressure-indicating-film.html?gclid=CNvJz-aXh6ICFVbE3AodNH0eUA
Using the data from these trials, adjust the taper function parameters accordingly.
Let me know if I can elaborate on anything.
Mike
Re: Pressure Inside a Paper Roll
06/04/2010 11:06 PM
Good answer mikerho!
"don't be so open minded that your brain falls out" unknown
06/05/2010 4:13 AM
Thanks Randyl.
I have been in the coating/laminating industry for about 6 years.
It is satisfying when you can provide information based on direct experience.
Are you in this industry as well?
Register to Reply 3 comments
