Previous in Forum: Soft Starters   Next in Forum: About Circuit Breaker for High Tension Transformers
Frequency Change Between Customer Supply & Equipment
06/05/2010 2:26 AM
What is the effective solution for changing voltage & frequency between the customer supply & equipment.
Re: Frequency change
06/05/2010 2:33 AM
Voltage change: transformer.
Frequency change: VFD or motor-generator with suitable drive ratio (typically 5:6 or 6:5).
06/05/2010 2:45 AM
On what concept is a motor-generator working
06/05/2010 6:50 AM
mechanical-shaft coupling concept
06/05/2010 12:09 PM
The frequency depends on the rpm of the generator and the number of its poles; rpm = 120 x Hz/npoles, where n is even. As a result, 60-Hz generators run at 3600, 1800, 1200, 900,... rpm; whereas 50-Hz generators run at 3000, 1500, 1000, 750,... rpm.
To convert frequency mechanically, you can use a motor whose rpm is in one of these series to drive a generator whose rpm is in the other. They could be connected via a gear or belt drive of appropriate ratio. Such a combination is called a motor-generator.
Good Answers: 39
Re: Frequency Change Between Customer Supply & Equipment
06/05/2010 10:45 PM
The short answer is www.aseapower.com product choices up to 500 KVA power capacity. Smallest is about 18KVA. Custom sizes may be possible.
Tell them what voltage, frequency, phases input and they will provide suitable output according to your needs. their products are used world wide to convert shore power to whatever is needed on board a ship.
Elnav
Anonymous Poster (1); elnav (1); mvv_designs79 (1); Tornado (2)
