Previous in Forum: Mercury PLC   Next in Forum: Profibus
Trunnion Vs Floating Ball Valves
06/07/2010 2:33 AM
I read a few discussions related ball valves here & the conclusion is that trunnion mounted ball valves are gnerally used for sizes 6" & above. And trunnion mounted ball valves provide block & bleed feature which is not available in floating ball valve designs.
But what if I need block & bleed feature in ESD valve sizes 2" or less. I saw a lot of manufacturers offering trunnion mounted ball valve design for as small as 1/2" size.
I would invite a discussion on related experiences for use in oil & gas/Petrochemical industry.
Re: Trunnion Vs Floating Ball Valves
06/07/2010 3:27 AM
I think two separate issues are being confused here. As ball valves become larger, the pressure difference (proportional to pipe/valve area) is imposed on the seal area (proportional to diameter). This will compress or even crush the seal unless some other bearing method such as trunnion mounting is used.
Block-and-bleed refers to configurations such as two valves in series, with a bleed-off branch valve between. This should not depend on trunnion mounting or otherwise, so long as the valves' construction is suited to their size and ΔP.
You might be interested in: Gas Valves, Industrial Valves, Solenoid Valves
