Previous in Forum: Rectifier Problem   Next in Forum: Per Unit Impedance of Transformer
Design of Lightning Arrestor System
06/10/2010 11:04 PM
Dear All,
I want to know about the design of lightning arrestor system network for an industry, height of structures on which these arrestors will be installed are known. Our main concern is how to estimate the lightning protection coverage radius given by each of these arrestors. Accordingly we intend to develop a general layout drawing of our plant with this information incorporated, also we want to know what all information we have to provide to a vendor of lightning arrestors so as to obtain a quote for the entire plant like height of structures on which these apparatus will be installed, meteorological conditions of the site etc....
Thanks,
Vivek
Re: Design of Lightning Arrestor system
06/11/2010 2:13 AM
Dear Mr.Vivek 1981,
Please refer my reply dt o6-5-2010 on this subject. Please
remember the topics as you read the threads in this forum and do not waste our &
your time.
Manroop.Chennai.
06/11/2010 1:27 PM
Dear vivek,
Sorry for our former CEO s (Manroop) negative reply. You can ignore it as he is not incharge now. We already removed him from the post.
Director
CR4
06/12/2010 2:13 AM
Good one! GOAT (Great Off-Topic Answer) as Redfred would say
Good Answers: 170
06/11/2010 10:11 PM
Please get a copy of IS 2319 (The Indian Standard Code of Practice for Protection of Buildings & Structures against Lightning). If you read it sincerely, you can design Lightning Protection System for any type of building or structure. It is an excellent guide material on the subject.
06/12/2010 3:47 PM
The field is deep and wide and very technical, but a good rule of thumb is to draw a line at a 45 degree angle from the top of the lightning rod to the ground.
Anything inside of this cone will generally be provided protection.
A very crude approximation, but a lot of good science behind it.
HTRN
06/13/2010 6:18 AM
Since thunder strikes and discharge differs according to locations, a design specification will be necessary for a particular area. An important factor to note is that the higher the spike, the more the radius of protection.A standard value of 100m radius is usually adopted, meaning if there is a good lightning arrestor within a vicinity of 100m radius, installing another spike in such vicinity is waste of resources.
There are different types of thunder spikes available in the market to day, the important issue is to select the one that will achieve Ur purpose. Factors to be considered in Ur selection are mainly peak values of discharged current and voltage.
Calculation for the above and standard tables can be gotten from the following websites.
1) www.sholarshipinindia.com on the topic How does lightning arrestor work.
2) cnxierli.en.alibaba.com/ESE_lightning_arrestor_rod_thunder_protector--- on radius calculation and tables.
Dickson.
There is peace in silence and achievement in plans.
Register to Reply 6 comments
Anonymous Poster (3); Dickson (1); electricalexpert65 (1); manroop (1)
