Previous in Forum: Design of Lightning Arrestor System   Next in Forum: Lightning Arrestor
Per Unit Impedance of Transformer
06/11/2010 12:12 AM
Sir Please Tell me that what is per unit impedance & if we want to make parallel operation of following trf then what is per unit impedance & how we can calculate please tell me im very confused for this.
1)132/33 KV , 40/50 MVA trf & 16/20 MVA trf.
2) 132/33 KV ,16/20 MVA trf. & 14/20 MVA trf.
Good Answers: 170
Re: Per Unit Impedence of transformer.
06/11/2010 10:06 PM
Please study the name plate of the transformer. Per unit impedance or percentage impedance would definitely be mentioned on the transformer name plate. It is a very importnat parameter for any transformer. Please note the same and come back, we will discuss further.
06/12/2010 3:31 AM
impedance is 6%.
Good Answers: 244
06/13/2010 10:05 PM
For the transformer, the Per Unit Impedance (%) = Percentage Impedance Voltage = Percentage Impedance (%Z). As already mentioned, it must be mentioned in the transformer name plate data.
See also http://cr4.globalspec.com/thread/41265
- MS
Good Answers: 170
06/15/2010 3:10 AM
It implies that when you load the transformer to its rated capacity, the Voltage Drop in the transformer secondary windings would be 6% of its no-load secondary voltage, when rated primary voltage is applied to the primary.
It also implies that with the secondary short-ciruited, if you apply 6% of the primary volatge , full-load rated current would flow in the secondary.
Conversely, it gives the short-circuit current supply capability of the transformer for a three phase terminal short circuit on the secondary windings (i.e.) Short circuit current = Transformer Rated Seconadry Full load current / Per unit impedance of the transformer.
Anonymous Poster (1); electricalexpert65 (2); msamad (1)
