Previous in Forum: How to Calculate P75, P90 & P95 Values for AEP Prediction in a Wind Power Plant   Next in Forum: Pump Suction Straight Length Requirement
Torque Required to Tighten M4 Brass Screw to Brass Plate
06/11/2010 8:53 AM
How much torque is required to tighten M4 x 12mm length Brass screw to Brass plate 15mm thick.
Good Answers: 183
Re: Torque Required to Tighten M4 Brass Screw to Brass Plate
06/11/2010 10:18 AM
Mechanical properties of the 2 brass parts ? If not know the recommandation can be too far from good and the risk to break the screw too big.
06/11/2010 4:10 PM
Define, "tighten".
Engineering Fields - Piping Design Engineering - New Member Engineering Fields - Mechanical Engineering - New Member
Good Answers: 27
06/15/2010 9:20 AM
Just like almost everybody else who asks "how much torque is required...", you're woefully lacking in prerequisite data :
Before you seek a target torque, you need to define how tight your screw has to be.
Then, you have to define how much friction might be encountered during the tightening procedure.
Be very careful: If some "expert" were to give you a torque value without asking for the above information, you and your cohort would end up screwing blindly in the dark
Best regards, HeviiGuy
BoltIntegrity (1); lyn (1); nick name (1)
