Previous in Forum: Torque Required to Tighten M4 Brass Screw to Brass Plate   Next in Forum: What Does Bearing Number Mean?
India - Member - Atul Singla Engineering Fields - Piping Design Engineering - Atul Singla- INDIA Engineering Fields - Mechanical Engineering - New Member
Pump Suction Straight Length Requirement
06/11/2010 11:32 AM
When there is a requirement of straight length (For example 5 D), i.e straight length is required between suction flange & first elbow.
Can we place reducer at the suction nozzle or we have to place the reducer after 5D straight pipe?
Please explain.
Atul singla
Good Answers: 38
Re: Pump Suction Straight Length Requirement
06/11/2010 12:52 PM
banu....
There is some difference in opinion on this matter, it is always best to get the manufacturer's requirements for the specific pump.
Generally speaking, for centrifugal pumps it is best to:
- Ensure that the suction piping diameter is one size larger than the suction nozzle
- Ensure that the fluid velocity is ~ 3-5 ft/sec
- A straight length of 3-5 of the LARGER SUCTION PIPE DIAMETERS (not the suction nozzle diameters) is desired
- Consult the Pump Handbook ( you already have a stolen copy) for more details
This is a piping layout guideline only....not good in all circumstances.
Your detailed evaluation and calculation of NPSH, of course, will govern the sucess of the installation.
You have done an NPSH evaluation...correct ?
Well why not ?
06/12/2010 2:43 AM
The reducer is preferred to be assembled directly into the suction flange to minimize any friction loss in suction line.
Very Important Note. The reducer at pump suction line must be eccentric type, and you have to verify its position, as TF (top flat) or BF (bottom flat)?
06/13/2010 11:57 AM
on the suction side of a pump(in general) if you make your return manifold larger than the supply, and use the first in last out design, it will tend to balance the system
Good Answers: 61
06/13/2010 5:49 PM
"use the first in last out design"
What do you mean by this, please explain.
Do it once and do it right
06/14/2010 9:37 AM
sorry, first in , last out , is only used in solar collectors, and heating manifolds, where you have a closed loop system, and circulators ( not pumps) are used. I rate Mjcronin 's reply, as very good.
06/15/2010 8:50 AM
Dear all
when we have to place a minimum 5D spool piece then can we place reducer at the suction nozzle??
Atul singla
12/15/2010 3:21 PM
Not only can you, it is recommended by most pump manufacturers because it increases the size immediately allowing for less pressure drop, allows air movement (no pockets), and most important helps keeps pump from vortexing. The 5d is from the face of the suction to the beginning of the 90 degree ell. This dim. allows for ecc. red. inline. Short answer YES.
Register to Reply 7 comments
Abdel Halim Galala (1); Anonymous Poster (1); MJCronin (1); munch (2); PennPiper (1); singlaatul (1)
