Previous in Forum: Pump Suction Straight Length Requirement   Next in Forum: Welding Cast Iron in Carbon Steel
9 comments
What Does Bearing Number Mean?
06/11/2010 11:59 AM
I 'd like to know what means the bearing number. Of course i know the meaning of ZZ Presently But what about the other letters & numbers please. Can somebody help me in this regard? A typical example would be 6309ZZC3GJN. What do C, 3,G,J and N mean? They may contain some information I suppose. Thanks
Good Answers: 183
Re: What Does Bearing Number Mean ?
06/11/2010 1:10 PM
Have you ever looked in a catalogue from SKF, Timken, FAG or INA ?
Do you know that bearing manufacturers edit catalogues ?
If you make the effort -oh! how big - to look in a catalogue you will find -oh! miracle - all what you want to know and even with DETAILS.
And because it seems that you do not know there is "google" where you ask and get answers .
And if you read the indications what to do before a question on CR4 you will find informations how you can find on your own up to a level every thing.
Make your research before asking questions you can get on your own the answers!
06/25/2010 4:24 AM
Dear Guru, all what u say is correct.But the problem i had was I was in a hurry & also I'm not a mechanical man , I'm an electrical man who started working with motors very recently. I had been engaged in power line construction until then. so forgive me.Anyway,some other kind people provided tailor made answers for my problem. lots of thanks all of you.---psrupasinghe
06/11/2010 1:27 PM
It'll help to start with the correct designation
63092 Z C3 GJN
06/11/2010 10:56 PM
Here's an example for you!
GE G100 ES-2RS
GE: symbol the type of bearings by letters
G100:
symbol the bearing size by letters and diameter size by number
ES-2RS:
symbol the structure characteristic, clearance and material by letter and number.
" Almost anything can be reversed through Engineering but not Human Life " WorKerZ
06/12/2010 1:32 AM
Some suffixes can vary with manufacturer (which you can find in a bearing catalogue) but most of them remain same. Different bearing manufacturers normally use many same abbreviations. Yes, you are right these numbers contain full information required. First two letter in a bearing number specifies the type of bearing i.e self alogning, angular contact or deep groove etc. For example in your case 63 is for deep groove ball bearing single row. Second two letter describes the size of bearing. For exmple in your case it is 09 which tells that the bore deameter of your bearing is 09x5=45mm. ZZ you already know is for meatallic shield on bith sides. C3 is for bearing having more than normal clearance, normally used in high temperature applications like small Steam Turbines. G,J and N can be different for different bearing manufacturers but for SKF J is for steel cage and N is for groove in the outer ring for snap ring. You can find more detail and bearing selection charts alongwith their descriptions on website thepetrostreet.com/forums
06/12/2010 10:56 AM
06/25/2010 4:34 AM
dear woodygb, I appreciate ur help .It saved me .the answer was short & sweet all the expected details were there. thank u soooo much & god bless u.
06/25/2010 4:41 AM
Dear machinedoc, I want to say a big thank u for ur detailed explanation . It improved my knowledge in bearings. thanks alot & god bless u---psrupasinghe
Re: What Does Bearing Number Mean?
02/20/2014 1:56 AM
Dear psrupashinghe,
ZZ refers to both sides of the bearing is SHIELDED.
Your question cannot be answered in one para or one page.
Pl. refer the MANUFACTURER's CATALOGUE which will describe fully and also guide how to select a bearing.
DHAYANANDHAN.S
Register to Reply 9 comments
dhayanandhan (1); machinedoc (1); nick name (1); psrupasinghe (3); woodygb (2); WoRkerz (1)
