The hole is a through hole, about 1/2 inch. 5/16-24 NF#3 which is P.D. of .2854-.2878 in. so we need an H1 tap.
Currently we are getting at least 2-4 holes per tap! which is to be expected I suppose. There are not many choices for H1 tap designed for this hard of material.
Ideas have been, tapping before heat treat, finding a better tap, and reaming to the highest size allowed by the print before tapping (thread whirling and EDM are not feasible for me).
Reaming to the highest allowed diameter has not made any difference in tool life. And I'm kinda hesitant to try tapping before heat treat because of the tight tolerance it's going to be hard to predict how much the material and threads will shrink and that will take testing, which takes time and money.
So far i'm waiting for quotes for a batch of "custom" taps that some suppliers might make, something that can tap this hard of steel and be an H1.
Any other suggestions or supplier recommendations would be appreciated.
Oh I almost forgot, I have heard of Serial taps and just wondering if it may be possible to use these to get an H1 tapped hole. It actually still might have to be a one off thing but might give us better tool life.
Thanks a bunch.
(I wrote all this out before and IE or cr4 crashed on me so i had to write it again!)
