Previous in Forum: Washing Machine Motor to Drive a Transfer Water Pump   Next in Forum: Breaker on 33kv Switch Gear Won't Close
Capacitor Rating with Single Phase Motor
06/13/2010 12:21 PM
how will you design capacitor rating of single phase motor
for power factor improvement?
Good Answers: 97
Re: Capacitor Rating with Single Phase Motor
06/13/2010 1:14 PM
From what I understand, the run capacitor rating on a capacitor-run type single phase motor is determined using algebraic phasor calculations.
This has been covered by a previous post: http://cr4.globalspec.com/thread/15299/Power-factor-correction-capacitor-for-Single-Phase-and-FHP-motors
CRTL-Z
06/14/2010 3:57 AM
Normally power factor of capacitor start single phase motors is much improved. Any how, for calculating the desired capacitor, follow the link;
http://cr4.globalspec.com/thread/53635/How-to-Calculate-Capacitor-Required-to-Compensate-Given-KVAR
Good Answers: 170
06/14/2010 10:11 AM
Capacitor provided in a single-phase motor is definitely not for imroving power factor, but to provide a split-phase to make the motor self-starting. It could be a Capacitor-start motor or a Permanent Capacitor Motor. Values of Capacitors will vary for Start Capacitor & Run capacitor.
The criteria for selection would be sufficient torque development only to over come the static inertia of the motor & the connected load.
One can refer to Electrical Machine Design by M.V. Deshpande.
Register to Reply 3 comments
electricalexpert65 (1); Signode (1); Unredundant (1)
