Previous in Forum: Breaker on 33kv Switch Gear Won't Close   Next in Forum: How to Calculate Phase Current of 3000 kVA Servo Stablizer
India - Member - New Member Engineering Fields - Electrical Engineering - New Member
UV Rays from Electric Arc Furnace
06/13/2010 8:28 PM
Its amazing when we look at the flexibility of electric power.We can even melt tonnes of heavy metals within 10 minutes with an electric arc furnace.Anybody got an idea of the UV radiation from electric arc and IR radiation from 1700 degree liquid metal effecting the furnace man.
Good Answers: 93
Re: UV Rays from Electric Arc Furnace
06/13/2010 11:16 PM
The furnace man will be hot if he is too near the pot.
Would you please supply information on how to melt with hots not grounded a bunch of pipes in the Gulf of Mexico?
You don't get wise because you got old, you get old because you were wise.
06/14/2010 10:58 AM
From the arc you will be getting a broad spectrum of electromagnetic radiation. I believe that most of the spectrum is IR but nothing prevents higher frequencies, including X-Ray. It all depends of the materials in the arc itself.
Good Answers: 804
06/14/2010 12:33 PM
there is definitely UV radiation as well. I worked for a time as a welder 30 years ago, I have deep 2nd degree burn scars to this day from a single hour I spent TIG welding where the top button on my shirt was loose and my chest skin was exposed.
Register to Reply 3 comments
JRaef (1); redfred (1); Transcendian (1)
You might be interested in: UV Filters, UV Sensors, UV Light Systems
