Previous in Forum: Demand Valve   Next in Forum: Solar Energy Disadvantages & Limitation
Supplier Lists
06/14/2010 9:43 AM
Once I have created a supplier list how can I save it and then access it later?
Re: Supplier Lists
06/14/2010 8:43 PM
Roger,
This has to be a trick question, right? You went to the trouble to sign up for this?
I'll save the obvious put-downs in the hope that you are asking a legitimate question.
OK, how did you create the list?
Ever hopeful.
Re: Supplier Lists
06/15/2010 10:02 AM
I created the list by reviewing suppliers on GlobalSpec and the addding them to my supplier list by clicking the dialogue box that reads" add to my supplier lkist".
After doing that for several suppliers I wanted to look at the list and then print it but I could not find the list. The only way I could access it was to select another supplier and click the add to my supplier list button again.
I was hoping that I could create several lists each of which had a diferent criteria and then save them for later use. Is tha possible? If so how do I do that and then access them?
This is not a trick question, I am new to Global Spec and could not find a help button or any way to resolve my question.
Thanks fo any help you can give me.
Re: Supplier Lists
06/15/2010 10:07 AM
Great! You have renewed my faith in humanity.
Contact Admin at cr4admin@globalspec.com and they can give you all the help you need.
They, Admin. are about on the site, too, to keep guys like Vader and me under control so they might see this and give you a hand.
Welcome to CR4.
Register to Reply 3 comments
You might be interested in: Access Doors, Access Control Systems, Access Points
