Previous in Forum: Opportunity for Engineers is Rapidly Shifting Towards East   Next in Forum: Supplier Lists
Good Answers: 60
Demand Valve
06/14/2010 2:08 AM
Hi anyone know of a small demand type valve for use with a jet washer.
i want to run water through a valve like device that will as fluid passes through alow a liquid to mix with the main stream of water.
the diameter of the valve should be no more than half inch and be adjustable.
I am sure there is such a device out there but to save a lot of searching i thought i would ask you lot.
Thanks
Good Answers: 97
Re: demand valve
06/14/2010 3:15 AM
Hi Perer
Have a look at venturi mixers.
I had one to mix the liquid fertiliser with water, It should work with detergent as well.
