I came across something of concern. Some wise guy installed for a supply to a distribution board, 14 x 25mm² 4 core cables in parallel, all connected to a bus bar set at each end and with an 800A circuit breaker at the supply end for protection. Manufacturer's tables allow a line current of ± 100A per 25mm² cable.
The protection thus grossly exceeds the maximum rating per cable.
Is there a ratio or prescription for protection of cables in parallel? One should be able to take advantage of the added current carrying capacity of cables in parallel to some extent, but within reason.
