Previous in Forum: Voltage Multiples of 11   Next in Forum: Instantaneous Peak Demand Metering Survey
18 comments
Electricity and Alcohol
06/15/2010 2:37 PM
I surprisingly noticed that I feel slight shock when touch switches after 3 to 4 pegs. Does alcohol increase the conductivity of body?
Re: Electricity and alchohol
06/15/2010 2:53 PM
Ethyl alcohol itself is not very conductive, nor I suspect are any the "contaminants" that flavor your particular beverage of choice.
However...it may be that the alcohol causes you to sweat a bit more, making your skin a tiny bit more conductive.
Good Answers: 804
Re: Electricity and Alcohol
06/15/2010 5:41 PM
I would think that alcohol will also make you more likely to touch electrical things that you might otherwise know better than to touch...
Good Answers: 143
06/15/2010 9:16 PM
Do you really have switches with several tens of volts on them? I'd think the wireman had a few pegs too.
Good Answers: 97
06/15/2010 9:40 PM
You should not be drinking the polyethylene glycol.
The shocks you are feeling are from the defibrillator!
CRTL-Z
06/16/2010 12:39 AM
Don't try touching any electricity item, terminal, when you are drunk.
(Oh!, but how you would know that it is electrical item, when you are drunk)!!!!
06/16/2010 1:31 AM
Better you will ask doctor.because he should know.You have some problem in your
body.Because my friend also having same problem even without drinking if he will touch any metel item he would get shock.Because of High blood cholesterol (i think so)I dont know exactly thats why i said better to ask doctor
06/16/2010 2:46 AM
Um-what is a peg?. The effects of alcohol consumption on human body conductivity of electron source to nerve endings in the skin is most likely due to alcohol dilating cappillaries which connect veins to nerves- so an increased feeling results- mind you, what you feel may not be felt by anyone else or it may- then again it is probably ALL in your MIND!!!. Thought of measuring switches with micro-voltmeter?.
06/16/2010 2:52 AM
Did you mean 3-4 kegs?
06/16/2010 5:02 AM
Sorry....peg means in our part of world is 60ml.
Good Answers: 97
06/16/2010 12:19 PM
I looked up "peg" and found it to be a common acronym for polyethylene glycol.
So I thought it was a joke.
A "40" in my part of the world will turn you into a joke.
CRTL-Z
06/16/2010 8:15 AM
That's why they call it "getting a buzz"!
06/16/2010 9:27 AM
Increase the Ingress Protection rating of the switches above IP2x, if necessary by replacing them. It won't matter then whether the toucher is drunk or sober.
Good Answers: 97
06/16/2010 9:48 AM
This may require a "hazardous location" classification. or at least IP 67.
CRTL-Z
06/16/2010 10:30 AM
I had the same problem. Chabge the brand. I switched to Baccardi, then it is found OK.Tequila also good
Good Answers: 61
06/16/2010 12:01 PM
Yes, alcohol increases conductivity (not directly, as alcohol is converted to glucose and other sugars immediately upon ingestion - it is a biocide, after all). Some other factors which also increase conductivity include fatigue, perspiration and some nutritional supplements.
06/18/2010 1:54 AM
I believe alcohol will definitely affect how you conduct yourself, but I'm not sure how it will change how you conduct electricity.
06/18/2010 1:58 AM
16 was me, must admit. I forgot to log on.
I do not 'know it all', but i will admit that I would like to. CJM
Good Answers: 11
06/18/2010 6:40 PM
For more information Click
Reply to Forum Thread 18 comments
Anonymous Poster (5); billg (1); CJMcGill (1); gsuhas (1); Hameedullah Ekhlas (1); JRaef (1); nasafly82 (1); Neil Kwyrer (1); pwr2thepeople (1); PWSlack (1); TVP45 (1); Unredundant (3)
