Previous in Forum: Instantaneous Peak Demand Metering Survey   Next in Forum: Differential Protection
Power Cable Selection
06/15/2010 3:12 PM
As we know, there are following things which are considered when we select a power cable for a motorize load
i.e:
· Cable laying method (under ground/in cable tray etc)
· Length of cable
· Load current
· Voltage drop etc
Is there any thumb rule for selecting a power cable that is near to the exact (calculated)
For example:
What will be the size of power cable for a 3-phase motor having FLA=100,440V,distance from MCC is 100 feet
Re: Power cable selection
06/15/2010 3:28 PM
For me if a cable like this fails you have so many problems.
I always overate cable by as much as I can and if you have a fault you can destroy the whole system and more.
A motor will draw more current on start up and then it depends on load.
You can measure or calculate the resistance of your system / wires from manufactures data but until completely built you can not be sure of all connections.
So as I say overate from any calculations you make...it is safer and will last longer.
There is many standards and calculators on the www's I use American yacht standards as they have the harshest environments.
I am a deeply religious nonbeliever - this is a somewhat new kind of religion. Albert Einstein
Good Answers: 11
06/15/2010 5:19 PM
Re: Power Cable Selection
06/16/2010 7:44 AM
i you to choose cables for this i think it is better you would refer to a standard ampacities, allowable voltage drops that will satisfy your needs..
you could use some software for this..
for the simulation i have made you could use 1/0 AWG cable that is if you have 440V fixed source..
06/16/2010 9:25 AM
→ British Standard 7671 as usual.
06/16/2010 3:50 PM
General guides, de-rating and sizing information are usually available on the cable manufacturer's website. Additionally the information can be found in the applicable local electrical standard you should be working to.
I personally find cable manufacturer's websites a good place to start.
Additionally you can try a search of CR4 for more details and website links (as this type of question has been answered many times before).
Hameedullah Ekhlas (1); hkian (1); jack of all trades (1); portugalphilip (1); PWSlack (1)
You might be interested in: Cable Laying Services, Cable Assemblies, Cable Trays
