Previous in Forum: Voltage Level   Next in Forum: K-rating selection
K-Rated Transformer
06/16/2010 2:38 PM
major mobile msc's used k-rated transformers why?
Good Answers: 11
Re: K-Rated Transformer
06/16/2010 3:36 PM
A standard transformer is not designed for high harmonic currents produced by non-linear loads and will overheat and fail prematurely when connected to these loads. For
this reason a special transformer has been designed. This transformer is a K-rated transformer. K-rated transformers are: able to handle the heat generated by harmonic
06/17/2010 12:22 PM
thank u sir,
Register to Reply 2 comments
You might be interested in: Transformers, Power Transformers, Telecom Transformers
