Previous in Forum: ISA5.1 & KKS Tagging   Next in Forum: GSD File
9 comments
Good Answers: 97
Self Powered LED Bar Graph Current Level Indicator.
06/17/2010 11:11 AM
There are small, self powered current indicators available that can used to indicate when a load is drawing current (above a set threshold). These devices consist of a ct with an LED moulded into a plastic housing that is panel mountable.
This device, mounted in a small junction box close to the application, allowed a customer (noisy paper mill) a visual indication/confirmation that a pump was actually running, without requiring a trip to the motor control room.
My question is: Would a LED bar graph to indicate current level, compact and self-powered be feasible?
CRTL-Z
Re: Self Powered LED Bar Graph Current Level Indicator.
06/17/2010 11:57 AM
It should be fairly easy, yes.
I'm a bit surprised somebody doesn't have such a thing off-the-shelf. You could do one up from scratch, which may or may not be up your alley. If not, I've seen a few intellegent bargraphs that you might be able to couple to some existing bit of equipment and tweak it into doing what you want.
It's got to be a bar graph and not a numerical display? Murata makes a lot of really nice self-powered panel ammeters with digits.
http://www.murata-ps.com/cgi-bin/cd4power.storefront/EN/Catalog/1013
Good Answers: 97
06/17/2010 12:37 PM
I am looking for a device powered by the current it is measuring, with no requirement for a power supply.
Check this link:
http://www.crmagnetics.com/products/Wire-Mounted-C29.aspx
I talked to these Guys and they did not seem interested.
Thanks for the reply.
CRTL-Z
Good Answers: 18
06/17/2010 4:23 PM
Sounds like what you want is a panel-mount ammeter like this one from http://www.boatersworld.com/product/MP80814855.htm?utm_medium=productsearch&utm_source=google
If the needle is anywhere other than zero, then the motor must be running. An old analog style gage like this may not require a power supply. Newer LED styles would probably require a DC power source, portable types operate for years on a 12V battery.
The most valuable of all talents is that of never using two words when one will do. ~Thomas Jefferson
Good Answers: 97
06/17/2010 4:42 PM
EElectrician,
I tried an analog meter and the conditions are too rough.
Thanks for the link though, I can use those on the floating dry dock apps.
CRTL-Z
06/17/2010 4:47 PM
It sounds like a loop powered indicator.
Digital value loop powered indicators are commonly available, but are typically LCD (black on gray), not LED (colored), in order to minimize the voltage drop the device produces in the loop.
If suitable for use in northern climates, they'd have to work at low temperatures and be suitable for outdoor mounting, rain tight, etc. An integral junction box would be required, I'd think. There's seldom exisiting junction boxes at eye level on tanks.
Good Answers: 97
06/17/2010 5:26 PM
Not knowing what is inside the one I used, I would have to say it is just an LED with the necessary dropping network connected to the c.t.
The vortex type pumps have a tendency to overload when there is not enough head pressure on them. If there were a way for an operator to watch a bar graph while throttling these pumps, without requiring anything other than a small enclosure on the cable.....
If someone could develop this, there is a definite market for it.
Go for it, and sell it to me when you get it perfected/patented.
CRTL-Z
06/18/2010 5:29 AM
How about just doing pressure measurement downstream of the pump? The current that the motor is drawing is of less significance than the pressure that it is developing, perhaps?
Good Answers: 18
06/18/2010 8:57 AM
I would agree with your suggestion. It would be better to configure a pressure switch and a contactor to stop the pump before the current spikes rather than waiting for an operator to stop it after the fact.
Good Answers: 97
06/18/2010 8:59 AM
Pressure or flow monitoring would be the way to go except this becomes complicated and expensive when pumping slurries.
I am looking for the least complicated method. Something I could offer to the customer at little or no cost to him/her.
I should have mentioned that these pumps are portable and flexible cord connected.
The LED bargraph elements would not have to stay on as the current increased, just the element representing the level. A color change (green, amber, red) would be ideal. Even a single multi colored LED would work.
CRTL-Z
Register to Reply 9 comments
Anonymous Poster (1); Carl_E (1); EElectrician (2); PWSlack (1); Unredundant (4)
