I'm analysing a component which has a U shaped notch cut in it. Using Petersons stress concentration factor book I can determine a k value but my question is this.
Peterson states this value is for a thin element and in my situation it is actually quite thick. Basically instead of it being a thin plate I've got the cross section of a pipe with an axial U shaped groove running the full length. How valid is the stress concentration factor found in the tables concidering my conditions are not the same as those stated in the book?
