Previous in Forum: Floor Drains Full of Concrete   Next in Forum: Capacity Temperature Control Valve
Underground Utility Services - Electrical
06/18/2010 11:15 PM
While designing underground electrical cabling what are the standards in deciding depth and lateral clearances with respect to other services like sewage, water lines; telecommunication, data cables etc. ?
Re: Underground utility services - Electrical
06/18/2010 11:31 PM
What standards do you use now?
06/21/2010 4:52 AM
IS 1255 gives minimum depth required, however when for example cable is to be laid along some u/g utility pipe line what shall be the horizontal clearance and what shall be at lower level w r t GL. What practice is followed and as per what standards. Is there any reference in NBC, or what standards / practices are followed in developed countries
06/19/2010 2:25 AM
For Cable sizing BS 7671 is widely excepted... you can check....
06/21/2010 4:54 AM
cable sizing is not the point
Register to Reply 4 comments
09.pathak (1); HemantSali (2); lyn (1)
