Previous in Forum: Futher Courses in Electrical Engineering   Next in Forum: PFC and Diesel Generator
18 comments
Fan Speed
06/20/2010 2:12 AM
How is speed of a fan (1ph induction motor) controlled as far as i observed series resistance is connected and we call it regulator. How is modern fan speed controlled ? i think resistor waste electricity.
Australia - Member - Igor...pull the switch!!!
Good Answers: 12
Re: Fan speed
06/20/2010 2:23 AM
http://www.freescale.com/files/microcontrollers/doc/app_note/AN3471.pdf
http://america.renesas.com/media/products/mpumcu/child_folder/Renesas_Jani_Seminar.pdf
speed controlled by voltage change or frequency change or many other finer methods...choose your flavour
CraziestOzzy
Good Answers: 18
Re: Fan speed
06/21/2010 2:16 AM
The resistor/s are sized correctly to suit the the load. This is your cheapest form of speed control, after this you get a winding per speed, which again cost more. All you waste here is the electricity in the form of heat. I'm not sure whether anybody will bother to calculate this "waste" I'm don't believe that the cost of the waste heat will be near the capital outlay required for an inverter, or any other electronic speed control. Besides why would one want to slow down a fan more than its slowest speed? ( Given that it is a tablefan?)
Always learning
Re: Fan speed
06/21/2010 10:41 AM
"Besides why would one want to slow down a fan more than its slowest speed? ( Given that it is a tablefan?)"
To make it quieter! (less audio noise)
Good Answers: 150
Re: Fan speed
06/21/2010 10:53 AM
or to stop blowing your papers around on (and off!) your desk.
Who is John Galt?
Good Answers: 119
Re: Fan speed
06/20/2010 3:10 PM
While you can design and build a speed controller for a 1 or 3-phase induction motor (you didn't specify which one), purchasing a Variable Frequency Drive for the 3-phase motor is usually a much easier solution.
Good Answers: 12
Re: Fan speed
06/20/2010 6:11 PM
deciphering the garbled english, I assumed OP was talking about a single phase
CraziestOzzy
Good Answers: 119
Re: Fan speed
06/20/2010 8:32 PM
Oops... sorry, my bad. I had a dyslexic moment and read 1 HP where the OP actually did ask for 1 PH.
Good Answers: 150
Re: Fan Speed
06/20/2010 10:31 PM
guys, he is asking about a simple tabletop fan.
Who is John Galt?
Re: Fan Speed
06/20/2010 11:40 PM
I believe you are right, or perhaps a floor or ceiling fan...
I have also wondered how they get three speeds; unfortunately, I've never taken one apart to find out. Can anyone say for sure?
Good Answers: 150
Re: Fan Speed
06/20/2010 11:53 PM
Multiple windings I'm fairly sure. speed one is winding one. speed two is winding two and speed three is both windings.
Who is John Galt?
Good Answers: 60
Re: Fan Speed
06/21/2010 3:11 AM
Yes thats how they do it, Multiple windings
Re: Fan Speed
06/20/2010 10:52 PM
The typical electronic you can buy at your local hardware store is generally a triac, or back to back SCRs,, they can be noisy, both electrically, and acoustically. More expensive, quieter and more efficient are variable frequency/voltage controllers.
Good Answers: 49
Re: Fan Speed
06/21/2010 12:08 AM
You are correct that ONE option to control an induction motor (fan or other use) is with a variable resister.
Yes- if one is used, it does waste electricity (turning it into heat) but it DOES control fan speed and does it "capital cost" cheaply. Variable winding motors with selector switches are BETTER, but maybe you NEED accurate flow control, not inexpensive control that does not meet the need. Another option for a FAN is to use a damper (inlet or outlet) which will control volume AND will result in lower energy usage due to fan law rules.
NO MATTER HOW WELL YOU HAVE DONE SO FAR, ALWAYS TRY TO BE BETTER TOMORROW.
Re: Fan Speed
06/21/2010 12:34 AM
Latest speed controllers for fan speed are done using Thyristors......when we rotate the regulator the gate voltage is varied inturn the output of the thyristor is varied.....this output is fed to the fan which now rotates at variable speed.
India - Member - New Member
Good Answers: 164
Re: Fan Speed
06/21/2010 3:18 AM
i thought that SCR or Triac based Fan regulators are the norm nowadays ? No wasted heat in the resistors ?
Re: Fan Speed
06/21/2010 3:21 AM
If you are from India- a reputed company called CROMPTON was selling ballast type fan regulator. It was about 2 to 3 times the price of resistor type speed regulator. I have it fitted in my house for 2 decades. It is just a ballast (or call it choke) with 5 tapping's. It does not get hot and does not waste energy in heat like resistor. Unfortunately not many people know it and few traders stock it. Triac or thyristor based fan controllers are cheap and produce lot of harmonics. Again the potentiometer used there goes bad as wiper contact gets worn out. Many stop working after about 1 year depending on usage!!! Best solution is choke with tappings. German company was making small size variac of say 0.5 Amps rating- unfortunately cost conscious, illiterate common man looks for cheaper solution (recommended by electrical contractors/ traders, architects etc!!)
Re: Fan Speed
06/21/2010 1:10 PM
As far as I remember the induction motor has a little problem working properly if the voltage drops below 80 % or so.
If you have a universal motor- that is a brushed motor, than you can vary its speed by varying the voltage( from zero to rated voltage)-includes variation by potentiometer.
The guys that said that the speed is controlled by controlling the number of wintings being used at one particular time are right. This works for both brushed and brushless(induction) motor. The bruushed motor also works in dc voltage, the induction doesn't, but you probably knew this.
In a hand mixer used in kitchen I found out that the speed variation for the universal motor is done by varying the stator windings - that is the stator has taps.
The same kind of motor I have found in desk fans -some 200W fans. The speed variation was done by stator taps.
nikolay
The time is ......now
Re: Fan Speed
06/21/2010 2:22 PM
Yes. Resistor definitely wastes considerable energy. It would be imprudent to neglect waste in today's world. Inverter is the solution. If one considers millions of inverters to be made for fan then the cost will drastically reduce. In India, we get solid state controllers for about 1.5 Euro.
Reply to Forum Thread 18 comments
a+x=z (1); Anonymous Poster (1); baxterm (1); CraziestOzzy (2); dkwarner (2); energygod (1); jvrj (1); kvsridhar (1); mjb1962853 (2); nikolay (1); nitin47 (1); peterg7lyq (1); Rorschach (3)
