Previous in Forum: High Vacuum Systems   Next in Forum: bubble size measurement using electrical technique
Stopping Oil Spew (Not a spill)
06/21/2010 8:51 AM
am not a real engineer, but have had some design experience and love to figure things out. I have thought as lot about this and it appears that a high tech solution may not be the fix. At those depths and temperatures, with oil not spilling but forcefully flowing out of the pipe it is going to take a solution that is simple and easy to do with a robot or sub. If the pipe is exposed, it may sound crazy but how about using the oil's own presure to help stop the leak? Have you ever seen a Chinese handcuff. The type kids used to play with. You stick your finger in it and the harder you try to pull it out the tighter it gets. Why not create a woven ploymer version on a much larger scale. with a valve at the top end and a gripping surface on the inside. Leave the valve open while placing the cuff over the pipe to allow the oil to flow. close the valve slowly and allow the pressure will tighten the cuff around the pipe. The harder it pushes the tighter the cuff will get. Use the oil's own power to neutralize it? Of course the cuff would have to be held in place while the valve is closed, but a cam ring or clamp of some type at the bottom that could be easily tightened with the robot claw may do the trick.
Re: Stopping Oil Spew (Not a spill)
06/21/2010 9:08 AM
Look around on the forum. This has been discussed before.
Not all of the oil is coming through the pipe. A lot of it is coming from leaks in the pipe below the sea floor. If you restrict the flow at the pipe opening, more oil will flow from the leaks below.
06/21/2010 9:23 AM
Yes that would be a problem. I wonder if that would make it possible to attach a pipe to the top of the valve and pump hydraulic cement into the pipe. Of course you may lose grip when the pressure is released too? It would have to be more of a secure attachment for that to be possible I would imagine. Maybe some type of compression fitting. But it would only work if there is a clean cut on the pipe. Then you would have to hope the cement would make it far enough down to seal the leaks beneath the sea floor as well. Not an easy task at that depth.
07/01/2010 6:07 PM
at that depth and temp. and 1400 psi x area of opening (maybe a 9" dia. pipe), quite a fix. Why not use the ideas suggested by the net makers and fisherman, and collect and harvest (and sell) the oil as if they were schools of fish. It's not Bee Pee's oil anymore.
Register to Reply 3 comments
Anonymous Poster (1); munch (1); technogeek007 (1)
