Previous in Forum: DG set rating   Next in Forum: Transformer Core Parameters
Prime power DG set
06/24/2010 1:50 AM
Is it true that prime power DG set to be loaded on average load of 70%.Why not full rated capacity
Re: Prime power DG set
06/24/2010 1:57 AM
For one reason, there should be some reserve capacity for starting any large motors that might be fed from the genset. This is similar to providing a safety factor for any well engineered system.
06/24/2010 8:12 AM
Besides that; rating of genset is in KVA and the load is in KW
Knowledge sharing is a WIN-WIN situation
Good Answers: 11
06/24/2010 4:19 PM
check generator's kVA, p.f and kW and compare it to your load kW. Do some calculation and you will get the reason.
Register to Reply 3 comments
Hameedullah Ekhlas (1); mountk2 (1); Tornado (1)
