Previous in Forum: Wind Generator Solar No Problem   Next in Forum: How to Design and Make a Low Cost, Low Tech. Solar Tracking System
Carbon Credits for Small Solar Systems
06/24/2010 7:07 AM
Dear All,
Please help me to find out:
How to Calculate Carbon Credits that one can accrue, by installing, say for example a solar water heater of 100 lit/day capacity and having solar collector area of 2 m2. Inlet water temp~200 C and the range of out let temperature attained is 70-800 C. Average Solar Radiation at our location is 1200 watt/ m2
Similarly these days solar assisted air conditioning systems are being marketed. For which manufacturers are claiming that these A/c units consume only 60% electricity compared to normal a/c systems, as some new refrigerant is being used in these systems. These systems heat the refrigerant in solar collectors. Two solar collectors (total area of 2 collectors is 4 m2) is installed with each solar assisted a/c unit. Pl help how to calculate the carbon credits for these types of systems.
Regards,
Dr N P Singh
Re: Carbon Credits for Small Solar Systems
06/24/2010 11:13 PM
You accrued 0 (Zero) Credits. If you figure out why, you know the various information that is missing in your question.
Good Answers: 54
06/25/2010 12:31 AM
Is that DOCTOR in front of your name?
Hopefully it's not a Phd in Engineering.
If there's something you don't understand...Then a wizard did it. As heard on "The Simpsons".
06/25/2010 12:42 AM
Yes Dear,
This forum does not give us mandate to ask personal questions, hence no personal questions please.
Regards,
Dr N P Singh
06/25/2010 1:27 AM
Other than the fact that this whole carbon credits thing is a huge scam . . .
Good Answers: 12
06/25/2010 3:02 AM
You get everything here: http://unfccc.int/2860.php
Subramanyam
Engineering Fields - Optical Engineering - New Member
06/25/2010 8:17 AM
It depends on your previous method of water heating, which is now replaced by solar heating system.Assuming your current system is replaced by electric heating system for heating 100 lt/day of water from 20oC to 80oC for 365 days an year you will generate about 1/40th ton of Carbon Credits (CC)/ year.I took 0.229 CO2/unit as CC generation for replacing use of electric heating (with no losses in the system).You would have generated more had your previous method of heating been usage of coal to heat water. To understand how one calculates CC you may visit, for example http://nz.carboncalcs.com/ccalcs.htm#. This information could be found by running a single and simple Google search.I think we should send queries to CR4 forum to find answers which otherwise would be difficult to get (eg.,from Internet).
United States - Member - American all the way Hobbies - Target Shooting - Aint nuthin like killing an innocent soup can!!!
06/25/2010 7:37 PM
A doctor that can't use google...
NOW I have seen it all
Give me enough duct tape and I can fix anything!
Register to Reply 7 comments
Anonymous Poster (1); Brave Sir Robin (1); farmatt (1); ffej (1); g srikanth (1); kvsubramanyam (1); npsdhillon (1)
